소개
This guide will aid you in replacing the wall sensor on your Botvac.
필요한 것
Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
Remove the four screws lining the front roller using a TR10 Torx screwdriver.
Remove the black panel behind and in front of the roller.
Gently lift the roller by the right side to remove it.
거의 끝나갑니다!
결론
