주요 콘텐츠로 건너뛰기
Neato Botvac Connected Screen Replacement
필요한 것
  1. Neato Botvac Connected Screen Replacement, Screen: 1 단계, 이미지 1/3 Neato Botvac Connected Screen Replacement, Screen: 1 단계, 이미지 2/3 Neato Botvac Connected Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
    • Remove the four screws lining the front roller using a TR10 Torx screwdriver.
    • Remove the black panel behind and in front of the roller.
    • Gently lift the roller by the right side to remove it.
  2. Neato Botvac Connected Screen Replacement: 2 단계, 이미지 1/1
    • Remove the two screws behind the front roller of the robot using a Phillips #2 screwdriver.
    • Remove the battery by lifting it out while pressing down on the wire clip inside the compartment.
  3. Neato Botvac Connected Screen Replacement: 3 단계, 이미지 1/3 Neato Botvac Connected Screen Replacement: 3 단계, 이미지 2/3 Neato Botvac Connected Screen Replacement: 3 단계, 이미지 3/3
    • Pull one side of the front bumper out and then forward toward you. Repeat on the other side to completely detach the front bumper.
  4. Neato Botvac Connected Screen Replacement: 4 단계, 이미지 1/2 Neato Botvac Connected Screen Replacement: 4 단계, 이미지 2/2
    • Remove the eight screws from the underside of the Botvac using a TR10 Torx screwdriver.
    • Remove the additional two TR10 screws from the top of the Botvac.
    • Remove the dustbin.
  5. Neato Botvac Connected Screen Replacement: 5 단계, 이미지 1/3 Neato Botvac Connected Screen Replacement: 5 단계, 이미지 2/3 Neato Botvac Connected Screen Replacement: 5 단계, 이미지 3/3
    • Pry the clips on the front of the robot apart.
    • Unplug the beige connector with a spudger, working one side at a time until it comes unplugged.
    • Make certain not to not to tear any wires out of the port.
    • Lay the top of the robot inside up.
  6. Neato Botvac Connected Screen Replacement: 6 단계, 이미지 1/2 Neato Botvac Connected Screen Replacement: 6 단계, 이미지 2/2
    • Unplug the beige connector with a spudger. Be careful not to tear out any wires.
    • Remove the two screws from the screen using a TR10 Torx screwdriver.
    • Remove the screen from the vacuum.
결론
Jerome
회원 가입일: 03/01/23
365 평판
안내서 2개 작성하였습니다
University of Delaware, Team 12-5, McGuire Spring 2023 University of Delaware, Team 12-5, McGuire Spring 2023 회원
UD-MCGUIRE-S23S12G5
5 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 147
