주요 콘텐츠로 건너뛰기
Neato Botvac D75 Brushes Replacement
필요한 것
  1. Neato Botvac D75 Brushes Replacement, Brushes: 1 단계, 이미지 1/3 Neato Botvac D75 Brushes Replacement, Brushes: 1 단계, 이미지 2/3 Neato Botvac D75 Brushes Replacement, Brushes: 1 단계, 이미지 3/3
    • To remove the rotary brush simply grasp it firmly and pull it off.
  2. Neato Botvac D75 Brushes Replacement: 2 단계, 이미지 1/3 Neato Botvac D75 Brushes Replacement: 2 단계, 이미지 2/3 Neato Botvac D75 Brushes Replacement: 2 단계, 이미지 3/3
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  3. Neato Botvac D75 Brushes Replacement: 3 단계, 이미지 1/1
    • Once the black piece has been taken out, the brush just comes out easily.
결론
Juan Cornejo
회원 가입일: 02/15/17
597 평판
안내서 5개 작성하였습니다
USF Tampa, Team S6-G5, Lacy Spring 2017 USF Tampa, Team S6-G5, Lacy Spring 2017 회원
USFT-LACY-S17S6G5
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
I have removed and cleaned the brush but it still won't run due to the error message to clean the brush. The machine has only run 5 or 6 times so brand new machine.
keytkey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 927
