주요 콘텐츠로 건너뛰기
Neato Botvac D8000 Top Face Panel Replacement
필요한 것
  1. Neato Botvac D8000 Top Face Panel Replacement, Top Face Panel: 1 단계, 이미지 1/1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac D8000 Top Face Panel Replacement: 2 단계, 이미지 1/2 Neato Botvac D8000 Top Face Panel Replacement: 2 단계, 이미지 2/2
    • Firmly pull the bumper forward at a steady pace.
    • When pulling the bumper forward avoid being too rough because the bumper might break.
  3. Neato Botvac D8000 Top Face Panel Replacement: 3 단계, 이미지 1/2 Neato Botvac D8000 Top Face Panel Replacement: 3 단계, 이미지 2/2
    • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
  4. Neato Botvac D8000 Top Face Panel Replacement: 4 단계, 이미지 1/3 Neato Botvac D8000 Top Face Panel Replacement: 4 단계, 이미지 2/3 Neato Botvac D8000 Top Face Panel Replacement: 4 단계, 이미지 3/3
    • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
  5. Neato Botvac D8000 Top Face Panel Replacement: 5 단계, 이미지 1/3 Neato Botvac D8000 Top Face Panel Replacement: 5 단계, 이미지 2/3 Neato Botvac D8000 Top Face Panel Replacement: 5 단계, 이미지 3/3
    • Push the clips, located in the back side, inward.
    • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
    • When you lift the top cover be careful because the wires are thin and fragile.
  6. Neato Botvac D8000 Top Face Panel Replacement: 6 단계, 이미지 1/1
    • Once you have carefully removed the wire clip; you can fully remove the top cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ruth Lopez
회원 가입일: 03/22/18
280 평판
안내서 2개 작성하였습니다
Sam Houston State, Team S17-G6, Blackburne Spring 2018 Sam Houston State, Team S17-G6, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 923
