주요 콘텐츠로 건너뛰기
Neato XV Signature Motor Assembly Replacement
필요한 것
  1. Neato XV Signature Motor Assembly Replacement, Motor Assembly: 1 단계, 이미지 1/2 Neato XV Signature Motor Assembly Replacement, Motor Assembly: 1 단계, 이미지 2/2
    • Flip your Neato XV Signature robot over so that so are looking at the underside of it.
  2. Neato XV Signature Motor Assembly Replacement: 2 단계, 이미지 1/1
    • Using a Phillips head #2 screwdriver, unscrew the four 14 mm (1.4 cm) screws on the external panel that covers the motor assembly.
    • Be sure not to lose the screws.
  3. Neato XV Signature Motor Assembly Replacement: 3 단계, 이미지 1/2 Neato XV Signature Motor Assembly Replacement: 3 단계, 이미지 2/2
    • Use plastic spudger to gently pry off the external panel to expose the motor assembly.
  4. Neato XV Signature Motor Assembly Replacement: 4 단계, 이미지 1/2 Neato XV Signature Motor Assembly Replacement: 4 단계, 이미지 2/2
    • Gently lift the motor assembly straight up, out of place, being aware of the four mounting posts that hold the motor firmly in place.
  5. Neato XV Signature Motor Assembly Replacement: 5 단계, 이미지 1/3 Neato XV Signature Motor Assembly Replacement: 5 단계, 이미지 2/3 Neato XV Signature Motor Assembly Replacement: 5 단계, 이미지 3/3
    • Press the tab and gently lift straight up to disconnect the motor wires.
  6. Neato XV Signature Motor Assembly Replacement: 6 단계, 이미지 1/3 Neato XV Signature Motor Assembly Replacement: 6 단계, 이미지 2/3 Neato XV Signature Motor Assembly Replacement: 6 단계, 이미지 3/3
    • After disconnecting the wire clip, remove the motor assembly out of the compartment.
    • With the replacement motor, you can now begin reassembly.
결론
To finish connecting the new motor assembly, follow these steps in reverse order. Be sure to replace the back external panel and four screws to tightly secure.
Emily Cardella
회원 가입일: 02/10/17
104 평판
안내서 1개 작성함
USF Tampa, Team 15-5, Remmell Spring 2017 USF Tampa, Team 15-5, Remmell Spring 2017 회원
USFT-REMMELL-S17S15G5
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 1,414
