주요 콘텐츠로 건너뛰기
Neato XV-21 Battery Replacement/Removal
필요한 것
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: 1 단계, 이미지 1/1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: 2 단계, 이미지 1/1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: 3 단계, 이미지 1/1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: 4 단계, 이미지 1/1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Fernando Aguilar
회원 가입일: 09/25/17
159 평판
안내서 1개 작성함
댓글 한 개
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 37
전체 시간: 1,218
