소개
This guide will show how to replace the dead, dying, or faulty batteries in your Neato XV-21.
필요한 것
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
This should be unnecessary. You should only need to remove the four screws from the battery doors. In this picture, the two lower-right screws are for one of the battery doors and the other is on the other side of the robot, under the demonstrator’s hands.
John - 답글
It is EIGHT screws, not SEVEN.
There are FOUR screws for the battery compartment panels (TWO for each).
FOUR screws for the fan access panel.
The panels are independent. There is no need to open the battery compartments to access the fan, nor vice versa.
Fred - 답글
