소개
This guide will help you disassemble your Neato XV-21 and replace the fan.
필요한 것
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
