필요한 것
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
Remove the 17 visible screws and the 2 covered/hidden screws near the battery compartments that connect the bottom to the top of the Neato robot.
Pinch and pull the white connectors that connect the LCD screen and motherboard components
다른 한 분이 해당 안내서를 완성하였습니다.
