소개
To replace the wheels you will want your device turned off and have a phillips screwdriver ready. This is a easy fix and should see the problem upon unscrewing the wheels.
필요한 것
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
다른 3명이 해당 안내서를 완성하였습니다.
