주요 콘텐츠로 건너뛰기
Necklace Barrel Clasp Repair
필요한 것
  1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: 1 단계, 이미지 1/2 Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: 1 단계, 이미지 2/2
    • Locate the broken part of the ring that attaches through the back of the barrel clasp.
    • Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
  2. Necklace Barrel Clasp Repair: 2 단계, 이미지 1/1
    • Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
    • The soldering iron tip can get extremely hot and will cause severe burns if comes into direct contact with skin. Ensure you keep a safe distance, and wear safety equipment.
    • This method is not recommended for precious metals.
  3. Necklace Barrel Clasp Repair: 3 단계, 이미지 1/1
    • Molten metal is extremely hot and will cause severe burns. Handle the soldering gun with care and keep your distance from the melting metal.
    • Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
    • Ensure the barrel clasp and ring connection is covered, allowing anywhere from 10 to 30 seconds for the bond to harden and cool.
  4. Necklace Barrel Clasp Repair: 4 단계, 이미지 1/1
    • Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
    • Do not pull too hard—the amount of strain may cause the solder to break.
결론
Garrett Key
회원 가입일: 07/12/17
107 평판
안내서 1개 작성함
Texas Tech, Team S1-G5, Rauch Summer 2017 Texas Tech, Team S1-G5, Rauch Summer 2017 회원
TTU-RAUCH-SU17S1G5
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 32
전체 시간: 2,724
