주요 콘텐츠로 건너뛰기
Neo3Do Battery & LED screen Replacement
필요한 것
  1. Neo3Do Battery & LED screen Replacement, Back Panel: 1 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement, Back Panel: 1 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement, Back Panel: 1 단계, 이미지 3/3
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
  2. Neo3Do Battery & LED screen Replacement: 2 단계, 이미지 1/2 Neo3Do Battery & LED screen Replacement: 2 단계, 이미지 2/2
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
  3. Neo3Do Battery & LED screen Replacement: 3 단계, 이미지 1/2 Neo3Do Battery & LED screen Replacement: 3 단계, 이미지 2/2
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
  4. Neo3Do Battery & LED screen Replacement: 4 단계, 이미지 1/1
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
  5. Neo3Do Battery & LED screen Replacement, Motherboard: 5 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement, Motherboard: 5 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement, Motherboard: 5 단계, 이미지 3/3
    • Remove all the tape attached to the motherboard.
  6. Neo3Do Battery & LED screen Replacement: 6 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 6 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 6 단계, 이미지 3/3
    • Pull out the black tabs using the plastic spudger.
    • All sockets that require the same step are marked in the first photo.
  7. Neo3Do Battery & LED screen Replacement: 7 단계, 이미지 1/2 Neo3Do Battery & LED screen Replacement: 7 단계, 이미지 2/2
    • Remove the wire belt from the socket.
  8. Neo3Do Battery & LED screen Replacement: 8 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 8 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 8 단계, 이미지 3/3
    • Lift the black tab and then remove the wire belt.
  9. Neo3Do Battery & LED screen Replacement: 9 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 9 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 9 단계, 이미지 3/3
  10. Neo3Do Battery & LED screen Replacement: 10 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 10 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 10 단계, 이미지 3/3
    • Grip the side of the tab and pull upwards to remove it from the socket.
    • Gripping the wire belt and pulling upwards may cause damage, be sure to avoid it.
  11. Neo3Do Battery & LED screen Replacement: 11 단계, 이미지 1/2 Neo3Do Battery & LED screen Replacement: 11 단계, 이미지 2/2
    • Remove the screws using the J0 head screwdriver.
    • All screws that require the same step are marked in the first photo.
  12. Neo3Do Battery & LED screen Replacement: 12 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 12 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 12 단계, 이미지 3/3
    • Grip the active(red) wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
    • Repeat the same process to remove the neutral(black) wire.
    • All wires that require the same steps are marked in the first photo.
    • The soldering tool is extremely hot, use with caution.
  13. Neo3Do Battery & LED screen Replacement: 13 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 13 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 13 단계, 이미지 3/3
    • Use the flat end of the plastic spudger to remove the motherboard and turn it underside-up.
  14. Neo3Do Battery & LED screen Replacement: 14 단계, 이미지 1/2 Neo3Do Battery & LED screen Replacement: 14 단계, 이미지 2/2
    • Remove the plug from the motherboard socket.
  15. Neo3Do Battery & LED screen Replacement: 15 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 15 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 15 단계, 이미지 3/3
    • Grip the wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
  16. Neo3Do Battery & LED screen Replacement, Battery & LED screen: 16 단계, 이미지 1/2 Neo3Do Battery & LED screen Replacement, Battery & LED screen: 16 단계, 이미지 2/2
    • Remove the screws with a J000 screwdriver
  17. Neo3Do Battery & LED screen Replacement: 17 단계, 이미지 1/2 Neo3Do Battery & LED screen Replacement: 17 단계, 이미지 2/2
    • Use the plastic removal tool to remove the plastic frame.
  18. Neo3Do Battery & LED screen Replacement: 18 단계, 이미지 1/3 Neo3Do Battery & LED screen Replacement: 18 단계, 이미지 2/3 Neo3Do Battery & LED screen Replacement: 18 단계, 이미지 3/3
    • Using the plastic removal tool, lift the LED screen from the battery side, and use the tweezers to help lift the LED screen upwards.
결론
Daniel Evans
회원 가입일: 09/26/16
431 평판
안내서 4개 작성하였습니다
USF Tampa, Team 14-3, Eyestone Fall 2016 USF Tampa, Team 14-3, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G3
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Do you have a source for Neo3DO Digitizer replacement.
Chris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 185
