주요 콘텐츠로 건너뛰기
Neo3Do Front and Back Camera Replacement
필요한 것
  1. Neo3Do Front and Back Camera Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Neo3Do Front and Back Camera Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Neo3Do Front and Back Camera Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
  2. Neo3Do Front and Back Camera Replacement: 2 단계, 이미지 2개 중 1개 Neo3Do Front and Back Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
  3. Neo3Do Front and Back Camera Replacement: 3 단계, 이미지 2개 중 1개 Neo3Do Front and Back Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
  4. Neo3Do Front and Back Camera Replacement: 4 단계, 이미지 1개 중 1개
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
  5. Neo3Do Front and Back Camera Replacement, Front and Back Camera: 5 단계, 이미지 3개 중 1개 Neo3Do Front and Back Camera Replacement, Front and Back Camera: 5 단계, 이미지 3개 중 2개 Neo3Do Front and Back Camera Replacement, Front and Back Camera: 5 단계, 이미지 3개 중 3개
    • Remove the front and back camera from their sockets.
    • Remove the silver tape from the battery.
  6. Neo3Do Front and Back Camera Replacement: 6 단계, 이미지 3개 중 1개 Neo3Do Front and Back Camera Replacement: 6 단계, 이미지 3개 중 2개 Neo3Do Front and Back Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the ribbon wire from the socket.
    • Gripping the wire belt and pulling upwards may cause damage, be sure to avoid it.
결론
작성자
1다른 기여자 명과 함께
Daniel Evans
회원 가입일: 09/26/16
431 평판
안내서 4개를 작성함
USF Tampa, Team 14-3, Eyestone Fall 2016 USF Tampa, Team 14-3, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G3
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 3
전체 시간: 187
