주요 콘텐츠로 건너뛰기
Nerf Dart Tag Furyfire Large Spring Replacement
필요한 것
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: 1 단계, 이미지 1/1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: 2 단계, 이미지 1/1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: 3 단계, 이미지 1/1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: 4 단계, 이미지 1/2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: 4 단계, 이미지 2/2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
결론
Bradley Penrow
회원 가입일: 09/23/14
37 평판
안내서 4개 작성하였습니다
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 1,444
