주요 콘텐츠로 건너뛰기
Nerf Dart Tag Furyfire Pump Track Replacement
필요한 것
  1. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the screws: 1 단계, 이미지 1/1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Panel: 2 단계, 이미지 1/1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Black Cylinder: 3 단계, 이미지 1/1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: 4 단계, 이미지 1/2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: 4 단계, 이미지 2/2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Pump Handle: 5 단계, 이미지 1/1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Handle: 6 단계, 이미지 1/1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: 7 단계, 이미지 1/2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: 7 단계, 이미지 2/2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Pump Track Replacement, Disengage White Piece: 8 단계, 이미지 1/1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: 9 단계, 이미지 1/2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: 9 단계, 이미지 2/2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bradley Penrow
회원 가입일: 09/23/14
37 평판
안내서 4개 작성하였습니다
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 11
전체 시간: 471
