주요 콘텐츠로 건너뛰기
Nerf Dart Tag Swarmfire Motor Spring Replacement
필요한 것
  1. Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: 1 단계, 이미지 1/2 Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: 1 단계, 이미지 2/2
    • Using the JIS #1 screwdriver, loosen the nine screws, holding the outer yellow shell in place
    • The screwdriver you'll be using is a J1 head from the 64 Bit Kit.
    • Be sure to sure to use the Magnetic Project Mat to prevent loss of the screws.
  2. Nerf Dart Tag Swarmfire Motor Spring Replacement: 2 단계, 이미지 1/1
    • Lift off the outer yellow shell.
  3. Nerf Dart Tag Swarmfire Motor Spring Replacement: 3 단계, 이미지 1/3 Nerf Dart Tag Swarmfire Motor Spring Replacement: 3 단계, 이미지 2/3 Nerf Dart Tag Swarmfire Motor Spring Replacement: 3 단계, 이미지 3/3
    • Remove the screw holding the battery compartment shut.
    • Lift off the inner blue casing
  4. Nerf Dart Tag Swarmfire Motor Spring Replacement: 4 단계, 이미지 1/3 Nerf Dart Tag Swarmfire Motor Spring Replacement: 4 단계, 이미지 2/3 Nerf Dart Tag Swarmfire Motor Spring Replacement: 4 단계, 이미지 3/3
    • Lift off the blue casing, exposing the white motor spring compartment.
    • Loosen and remove the three screws holding the white compartment door shut.
  5. Nerf Dart Tag Swarmfire Motor Spring Replacement: 5 단계, 이미지 1/2 Nerf Dart Tag Swarmfire Motor Spring Replacement: 5 단계, 이미지 2/2
    • Unsnap the white compartment into two pieces.
  6. Nerf Dart Tag Swarmfire Motor Spring Replacement: 6 단계, 이미지 1/3 Nerf Dart Tag Swarmfire Motor Spring Replacement: 6 단계, 이미지 2/3 Nerf Dart Tag Swarmfire Motor Spring Replacement: 6 단계, 이미지 3/3
    • Remove the motor spring located inside the rotating barrel and replace.
결론
Sonal Purohit
회원 가입일: 07/25/16
115 평판
안내서 1개 작성함
University of Memphis, Team 2-3, Kim SU 2016 University of Memphis, Team 2-3, Kim SU 2016 회원
UM-KIM-SU16S2G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 872
