주요 콘텐츠로 건너뛰기
Nerf N-Strike Deploy CS-6 Dart Tooth Replacement
필요한 것
  1. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement, Dart Tooth: 1 단계, 이미지 1/1
    • Before releasing the device in Stealth mode, take out hidden screws as shown
    • Extend the device in Stealth Mode by pressing the button found on the handle.
  2. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 2 단계, 이미지 1/3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 2 단계, 이미지 2/3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 2 단계, 이미지 3/3
    • Take out the screws from the pump.
    • Proceed to take out the other screws from the device to take off the cover.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 3 단계, 이미지 1/2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 3 단계, 이미지 2/2
    • Once the screws are out, you are able to take the cover piece off.
    • Proceed to remove the screws
    • Taking off those screws are vital in replacing the dart tooth.
  4. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 4 단계, 이미지 1/1
    • Carefully place cover piece above the device.
  5. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 5 단계, 이미지 1/1
    • Unscrew as shown to aid in the replacement.
  6. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 6 단계, 이미지 1/1
    • To take out the dart tooth, push the spring to the left.
    • The dart tooth should pop out with ease.
  7. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 7 단계, 이미지 1/1
    • Once pulled away from the device, take off the orange piece connected to the darth tooth
    • The piece can be identified with the spring.
  8. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 8 단계, 이미지 1/1
    • You should now be able to pull apart the dart tooth from the device.
    • The piece that has been pulled away will have a type of lubrication. If this piece requires replacement, it will slide on with ease.
  9. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 9 단계, 이미지 1/1
    • Make any adjustment to the dart tooth as seen. May be pulled either up or down.
    • Place in the replacing piece in order to fix the darth tooth
  10. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 10 단계, 이미지 1/3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 10 단계, 이미지 2/3 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 10 단계, 이미지 3/3
    • Place back on the orange piece with the spring to its original spot on the dart tooth.
    • While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
    • Place back cover pieces in order to secure the screws back into place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alec Hernandez
회원 가입일: 09/28/16
126 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 2,932
