주요 콘텐츠로 건너뛰기
Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement
필요한 것
  1. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement, Light-bulb Lens: 1 단계, 이미지 1/1
    • Proceed to take out the hidden screws when the device is collapsed.
    • Hidden screws measure out to 1.7 cm
  2. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 2 단계, 이미지 1/2 Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 2 단계, 이미지 2/2
    • Once the hidden screws are out, extend your device in stealth mode.
    • Once the device is extended out, proceed to take out the necessary screws as shown.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 3 단계, 이미지 1/1
    • Once all the necessary screws are taken off, the interior of your device should be visible.
    • Unscrew the orange barrel located in front of your device.
  4. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 4 단계, 이미지 1/1
    • Now that the cover is off and the screws are out, pry off the barrel of the device.
  5. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 5 단계, 이미지 1/1
    • Once the orange barrel of the device has been pried off, proceed to take the metal clip off from where it is currently located.
  6. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 6 단계, 이미지 1/2 Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 6 단계, 이미지 2/2
    • As shown, use your Phillips #0 head screwdriver to unscrew the highlighted areas
  7. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 7 단계, 이미지 1/1
    • Once all the screws have been removed, the cover for the light-bulb is able to come off.
    • Gently remove the cover to maintain the safety of your device.
  8. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 8 단계, 이미지 1/1
    • When taking off the cover piece, gently place it above the device as shown.
    • Regarding the ligh-bulb cords, it should have a strip of tape to keep it down.
  9. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 9 단계, 이미지 1/1
    • Near the light-bulb is the lens. Gently pry it off.
    • Correctly dispose your damaged lens.
  10. Nerf N-Strike Deploy CS-6 Light-bulb Lens Replacement: 10 단계, 이미지 1/1
    • Once you acquire your new lens, gently place it in front of the bulb.
    • As shown, the lens should be placed where the edges line up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alec Hernandez
회원 가입일: 09/28/16
126 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 839
