소개
The internal spring mechanism is what helps fire the darts from the device. A damaged internal spring can cause difficulty in firing and ultimately decrease the performance. This guide will show you step-by-step on how to pull apart the cover piece of the device to access the internal spring. Upon doing so, you will be shown how to properly place in a new spring to effectively increase the device's performance.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
