주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement
필요한 것
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: 1 단계, 이미지 1/3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: 1 단계, 이미지 2/3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: 1 단계, 이미지 3/3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: 2 단계, 이미지 1/3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: 2 단계, 이미지 2/3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: 2 단계, 이미지 3/3
    • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 3 단계, 이미지 1/2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 3 단계, 이미지 2/2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 4 단계, 이미지 1/3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 4 단계, 이미지 2/3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 4 단계, 이미지 3/3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 5 단계, 이미지 1/2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 5 단계, 이미지 2/2
    • Remove the two 5mm phillips screws from the rifle muzzle.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 6 단계, 이미지 1/1
    • Remove the muzzle and barrel from the rifle body.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: 7 단계, 이미지 1/1
    • Separate the muzzle from the barrel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elizabeth Coffey
회원 가입일: 01/26/14
404 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014 회원
CPSU-MANESS-W14S10G35
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 5,869
