주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement
필요한 것
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Notes Before Starting: 1 단계, 이미지 1/1
    • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • Be sure that the rifle is discharged and unloaded before starting disassembly.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Rear Cap Removal: 2 단계, 이미지 1/3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Rear Cap Removal: 2 단계, 이미지 2/3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Rear Cap Removal: 2 단계, 이미지 3/3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Slide Removal: 3 단계, 이미지 1/3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Slide Removal: 3 단계, 이미지 2/3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Slide Removal: 3 단계, 이미지 3/3
    • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 4 단계, 이미지 1/2 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 4 단계, 이미지 2/2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 5 단계, 이미지 1/3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 5 단계, 이미지 2/3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 5 단계, 이미지 3/3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Spring Removal: 6 단계, 이미지 1/1
    • You should now be able to pull the main firing spring from the rear of the rifle.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Henrique Chan
회원 가입일: 01/24/14
303 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014 회원
CPSU-MANESS-W14S10G35
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 25
전체 시간: 6,664
