주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Keep your Nerf N-Strike Elite Hail-Fire running with new batteries.
부품
지정된 부품이 없습니다.
  1. Remove the two 9.0 mm Phillips screws from the battery compartment.
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Pull the battery compartment out and away from the gun.
    • Pull the battery compartment out and away from the gun.
  3. Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jonathan Peck
회원 가입일: 2014년 01월 24일
184 평판
안내서 1개 작성함
Cal Poly, Team 13-13, Regan Winter 2014 Cal Poly, Team 13-13, Regan Winter 2014 회원
CPSU-REGAN-W14S13G13
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 31
30일 전: 141
전체 시간: 20,395
