소개
Use this guide to detach the damaged left shell so you'll be able to replace it with an undamaged shell. This guide can also be used with the 5 other Nerf N-Strike Elite Hail-Fire guides to replace other parts.
도구
부품
부품은 필요하지 않습니다.
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
다른 한 분이 해당 안내서를 완성하였습니다.
