주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Hail-Fire Left Shell Replacement
필요한 것
  1. Nerf N-Strike Elite Hail-Fire Left Shell Replacement, Left Shell: 1 단계, 이미지 1/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement, Left Shell: 1 단계, 이미지 2/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement, Left Shell: 1 단계, 이미지 3/3
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
  2. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 2 단계, 이미지 1/1
    • Remove the five 9.0 mm Phillips screws securing the trigger.
  3. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 3 단계, 이미지 1/2 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 3 단계, 이미지 2/2
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
  4. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 4 단계, 이미지 1/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 4 단계, 이미지 2/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 4 단계, 이미지 3/3
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
  5. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 5 단계, 이미지 1/1
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
  6. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 6 단계, 이미지 1/1
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
  7. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 7 단계, 이미지 1/1
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
  8. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 8 단계, 이미지 1/1
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
  9. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 9 단계, 이미지 1/2 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 9 단계, 이미지 2/2
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
  10. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 10 단계, 이미지 1/2 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 10 단계, 이미지 2/2
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
  11. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 11 단계, 이미지 1/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 11 단계, 이미지 2/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 11 단계, 이미지 3/3
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
  12. Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 12 단계, 이미지 1/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 12 단계, 이미지 2/3 Nerf N-Strike Elite Hail-Fire Left Shell Replacement: 12 단계, 이미지 3/3
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron Poon
회원 가입일: 01/24/14
229 평판
안내서 1개 작성함
Cal Poly, Team 13-13, Regan Winter 2014 Cal Poly, Team 13-13, Regan Winter 2014 회원
CPSU-REGAN-W14S13G13
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 920
