소개
Use this guide to remove the circuit board that activates the automatic firing mechanism.
필요한 것
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
Once you have the handle disassembled locate the triggering circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi, my Trigger circuit board has a white build up on it.
im not sure if this is a sign of a fried circuit, but my gun won’t rev up. Is there anything I can do?
its located in one of the 6 little metal sauter marks in the middle of it.
