소개
Use this guide to remove the circuit board that activates the automatic firing mechanism.
필요한 것
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
Remove the firing pin.
Once you have the handle disassembled locate the triggering circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi, my Trigger circuit board has a white build up on it.
im not sure if this is a sign of a fried circuit, but my gun won’t rev up. Is there anything I can do?
its located in one of the 6 little metal sauter marks in the middle of it.
