주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Retaliator Barrel Replacement
필요한 것
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: 1 단계, 이미지 1/1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: 2 단계, 이미지 1/1
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: 3 단계, 이미지 1/1
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: 4 단계, 이미지 1/1
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: 5 단계, 이미지 1/1
    • Remove the orange barrel from the assembly.
결론
다른 6명이 해당 안내서를 완성하였습니다.
ericharman
회원 가입일: 03/02/16
1,410 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 32
전체 시간: 11,490
