주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement
필요한 것
  1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Case Disassembly: 1 단계, 이미지 1/1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 4 단계, 이미지 1/2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 5 단계, 이미지 1/2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 5 단계, 이미지 2/2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Air Chamber: 6 단계, 이미지 1/1
    • The firing spring may be energized. If so, carefully release and spring pressure before proceeding.
    • While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
  7. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 7 단계, 이미지 1/1
    • Slide the white air chamber forward and remove the white alignment bracket.
  8. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 8 단계, 이미지 1/1
    • Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
결론
다른 16명이 해당 안내서를 완성하였습니다.
ericharman
회원 가입일: 03/02/16
1,410 평판
안내서 5개 작성하였습니다
댓글 4개
Where did we found the pièces??
Albert Einstein - 답글
where i can buy for spare part “air chamber”?
sabeni83_king - 답글
this tutorial helped A LOT
Daniel MacDonald - 답글
OK I've removed the air chamber now what?
camper234 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 47
전체 시간: 20,074
