소개
Moving components in your blaster can be accessed by removing the outer casing. This guide shows how to access these inner components.
필요한 것
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
다른 28명이 해당 안내서를 완성하였습니다.
댓글 14개
How do I clean the slider track?
you probably should not do that. i think its oily for a reason.
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Boo this sucks
Mark Green - 답글
