주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Retaliator Spring Replacement
필요한 것
  1. Nerf N-Strike Elite Retaliator Spring Replacement, Case Disassembly: 1 단계, 이미지 1/1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Spring Replacement: 2 단계, 이미지 1/1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Spring Replacement: 3 단계, 이미지 1/1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Spring Replacement: 4 단계, 이미지 1/2 Nerf N-Strike Elite Retaliator Spring Replacement: 4 단계, 이미지 2/2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Spring Replacement: 5 단계, 이미지 1/2 Nerf N-Strike Elite Retaliator Spring Replacement: 5 단계, 이미지 2/2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: 6 단계, 이미지 1/2 Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: 6 단계, 이미지 2/2
    • The spring may be compressed. If so, carefully release spring pressure before proceeding.
    • While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
결론
다른 11명이 해당 안내서를 완성하였습니다.
ericharman
회원 가입일: 03/02/16
1,410 평판
안내서 5개 작성하였습니다
댓글 2개
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
Ryan Zhang - 답글
can i use a nerf kronos spring
jordan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 32
전체 시간: 12,584
