주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
필요한 것
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: 1 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: 1 단계, 이미지 2개 중 2개
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 2 단계, 이미지 1개 중 1개
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 3 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 3 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 4 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 4 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 4 단계, 이미지 3개 중 3개
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 5 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 5 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 6 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 6 단계, 이미지 2개 중 2개
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Levi Rushing
회원 가입일: 09/08/21
148 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 43
전체 시간: 3,813
