소개
This guide is going to show you how to take apart the blaster to reach the spring that is located in cocking mechanism of the Nerf.
필요한 것
Remove the screw on the inside of the gun.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
다른 17명이 해당 안내서를 완성하였습니다.
댓글 20개
Where does the locking tab in step 5 go
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
