주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement
필요한 것
  1. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Outer Shell: 1 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Outer Shell: 1 단계, 이미지 2/2
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 2 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 2 단계, 이미지 2/2
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 3 단계, 이미지 1/1
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 4 단계, 이미지 1/1
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 5 단계, 이미지 1/1
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
    what is a locking tab? and where do i see it? sorry my english is bad
    JoseRafael - 답글
    its the front sight post
    Seth Mains - 답글
  6. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Spring Piston Chamber: 6 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Spring Piston Chamber: 6 단계, 이미지 2/2
    • First, remove the outer parts of the blaster, starting with the top part of the cocking mechanism. Then remove the full cover itself.
  7. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 7 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 7 단계, 이미지 2/2
    • Remove the barrel and the front part of the blaster. The components should simply slide off.
  8. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 8 단계, 이미지 1/1
    • Remove the screw on the inside of the gun.
    • Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  9. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 9 단계, 이미지 1/3 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 9 단계, 이미지 2/3 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 9 단계, 이미지 3/3
    • Remove the trigger, the cocking holdback, and the air compressor chamber
  10. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 10 단계, 이미지 1/1
    • Remove the spring holding the air compressor together.
  11. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 11 단계, 이미지 1/1
    • Remove the spring air compressor component.
  12. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 12 단계, 이미지 1/3 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 12 단계, 이미지 2/3 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 12 단계, 이미지 3/3
    • This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work.
    When I removed the compressor unit I found the little orange plastic needle on the tip was sticking ever so slightly when I pushed on it. I used a cotton swab and rubbing alcohol to clean inside, reassembled, and now it works like a charm!
    mybranehurtz - 답글
    I did everything you said but my blaster still doesn`t work. But all things are still working so nothing is broken. Why does it not work although??
    Steven-Rae Hein - 답글
    I dont know wats the problem sometimes it rotates sometimes not sometimes i fires sometimes it does not
    Adrian Lindgren - 답글
결론
다른 7명이 해당 안내서를 완성하였습니다.
Dylan Cooper Dalrymple
회원 가입일: 01/15/15
741 평판
안내서 3개 작성하였습니다
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G4
4 회원들
안내서 12개 작성하였습니다
댓글 4개
mi nerf strongarm no dispara los dardos con la misma potencia que cuando la utilice por primera vez, dispara los dardos demasiado suave
juanestebanlopezcastrillon - 답글
Maybe the problem is the dards.
Álvaro Sousa PT -
My nerf elite disruptor's drum some times working but sometimes notworkin
Skm - 답글
what is the size of the spring?
JoseRafael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 34
30일 전: 174
전체 시간: 31,443
