주요 콘텐츠로 건너뛰기
Nerf N-Strike Elite Strongarm Unloading Button Replacement
필요한 것
  1. Nerf N-Strike Elite Strongarm Unloading Button Replacement, Outer Shell: 1 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Outer Shell: 1 단계, 이미지 2/2
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 2 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 2 단계, 이미지 2/2
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 3 단계, 이미지 1/1
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 4 단계, 이미지 1/1
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 5 단계, 이미지 1/1
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
  6. Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: 6 단계, 이미지 1/3 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: 6 단계, 이미지 2/3 Nerf N-Strike Elite Strongarm Unloading Button Replacement, Unloading Button: 6 단계, 이미지 3/3
    • Look inside the top cover of the blaster and locate the tab extending from the unloading button. It shouldn't be too hard to find as pictured since it will be the only orange piece.
    • Inspect the button's location for signs of debris impeding its operation. Replace if necessary.
    • Ensure the unloading button has a 45 degree angle contact surface.
  7. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 7 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 7 단계, 이미지 2/2
    • To make the relevant pieces accessible, remove the barrel from its position on the bottom half of the blaster cover.
  8. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 8 단계, 이미지 1/2 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 8 단계, 이미지 2/2
    • On the bottom half of the blaster, ensure the tab from the button makes contact with the barrel assembly.
    • Clear out any debris in the way, or replace the button as necessary.
  9. Nerf N-Strike Elite Strongarm Unloading Button Replacement: 9 단계, 이미지 1/3 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 9 단계, 이미지 2/3 Nerf N-Strike Elite Strongarm Unloading Button Replacement: 9 단계, 이미지 3/3
    • Reassemble and test the unloading button's functionality. The button should correctly lock and release the blaster's dart barrel!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexander Kim
회원 가입일: 08/27/15
832 평판
안내서 3개 작성하였습니다
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 39
전체 시간: 9,150
