소개
This guide will outline the steps to remove and replace your Nerf N-Strike Firestrike's batteries. You only need a #1 Phillips Screwdriver and your hands. This guide can be completed anywhere and in under five minutes.
필요한 것
Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
Slide out the two AAA batteries using your fingers.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
loved it it is amazing :)
arun patel - 답글
amazing loved it : )
arun patel - 답글
Thanks a lot!!
Do we rlly need alkaline batteries
This should be step 1
Samuel Garcia - 답글
