주요 콘텐츠로 건너뛰기
Nerf N-Strike Firestrike Firing Trigger Replacement
필요한 것
  1. Nerf N-Strike Firestrike Firing Trigger Replacement, Remove battery cover: 1 단계, 이미지 1/1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Firing Trigger Replacement: 2 단계, 이미지 1/2 Nerf N-Strike Firestrike Firing Trigger Replacement: 2 단계, 이미지 2/2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Firing Trigger Replacement, Blaster Casing: 3 단계, 이미지 1/1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Firing Trigger Replacement: 4 단계, 이미지 1/2 Nerf N-Strike Firestrike Firing Trigger Replacement: 4 단계, 이미지 2/2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Firing Trigger Replacement: 5 단계, 이미지 1/2 Nerf N-Strike Firestrike Firing Trigger Replacement: 5 단계, 이미지 2/2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: 6 단계, 이미지 1/2 Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: 6 단계, 이미지 2/2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jong Wan Kim
회원 가입일: 04/22/15
422 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 3,022
