주요 콘텐츠로 건너뛰기
Nerf N-Strike Firestrike Laser Assembly Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Nerf N-Strike Firestrike Laser Assembly Replacement, Remove battery cover: 1 단계, 이미지 1개 중 1개
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Laser Assembly Replacement: 2 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Laser Assembly Replacement, Blaster Casing: 3 단계, 이미지 1개 중 1개
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Laser Assembly Replacement: 4 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Laser Assembly Replacement: 5 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Laser Assembly Replacement, Laser Trigger: 6 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Assembly Replacement, Laser Trigger: 6 단계, 이미지 2개 중 2개
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
  7. Nerf N-Strike Firestrike Laser Assembly Replacement, Firing Trigger: 7 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Assembly Replacement, Firing Trigger: 7 단계, 이미지 2개 중 2개
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
  8. Nerf N-Strike Firestrike Laser Assembly Replacement, Laser Assembly: 8 단계, 이미지 1개 중 1개
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
  9. Nerf N-Strike Firestrike Laser Assembly Replacement: 9 단계, 이미지 3개 중 1개 Nerf N-Strike Firestrike Laser Assembly Replacement: 9 단계, 이미지 3개 중 2개 Nerf N-Strike Firestrike Laser Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
결론
작성자
7다른 기여자 명과 함께
Hayes Kimball
회원 가입일: 04/19/15
742 평판
안내서 5개를 작성함
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G6
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 160
