주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
You will be able to disassemble the Firestrike and remove the laser assembly. You will need nothing other than a number 1 Phillips screwdriver and your hands. This guide can be completed anywhere and is relatively straight forward.
부품
지정된 부품이 없습니다.
  1. Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Slide out the two AAA batteries using your fingers. Slide out the two AAA batteries using your fingers.
    • Slide out the two AAA batteries using your fingers.
  3. Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  5. Slowly pull apart the blaster casing, starting at the battery location. Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  6. For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box. For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  7. Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out. Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
  8. Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out. Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
  9. Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
  10. Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin. Slide the laser assembly out. Slide the laser assembly out.
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
결론
Hayes Kimball
회원 가입일: 2015년 04월 19일
706 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G6
3 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 115
