주요 콘텐츠로 건너뛰기
Nerf N-Strike Firestrike Wire Replacement
필요한 것
  1. Nerf N-Strike Firestrike Wire Replacement, Remove battery cover: 1 단계, 이미지 1/1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Wire Replacement: 2 단계, 이미지 1/2 Nerf N-Strike Firestrike Wire Replacement: 2 단계, 이미지 2/2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Wire Replacement, Blaster Casing: 3 단계, 이미지 1/1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Wire Replacement: 4 단계, 이미지 1/2 Nerf N-Strike Firestrike Wire Replacement: 4 단계, 이미지 2/2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Wire Replacement: 5 단계, 이미지 1/2 Nerf N-Strike Firestrike Wire Replacement: 5 단계, 이미지 2/2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: 6 단계, 이미지 1/2 Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: 6 단계, 이미지 2/2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
  7. Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: 7 단계, 이미지 1/2 Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: 7 단계, 이미지 2/2
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
  8. Nerf N-Strike Firestrike Wire Replacement, Laser Assembly: 8 단계, 이미지 1/1
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
  9. Nerf N-Strike Firestrike Wire Replacement: 9 단계, 이미지 1/3 Nerf N-Strike Firestrike Wire Replacement: 9 단계, 이미지 2/3 Nerf N-Strike Firestrike Wire Replacement: 9 단계, 이미지 3/3
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
  10. Nerf N-Strike Firestrike Wire Replacement, Wire: 10 단계, 이미지 1/2 Nerf N-Strike Firestrike Wire Replacement, Wire: 10 단계, 이미지 2/2
    • Pinch the clips holding the circuit board to the laser assembly and remove the circuit board.
  11. Nerf N-Strike Firestrike Wire Replacement: 11 단계, 이미지 1/1
    • Desolder the wires from the circuit board.
    • The positive wire is attached at the lower left, while the negative wire is attached at the middle of the bottom.
  12. Nerf N-Strike Firestrike Wire Replacement: 12 단계, 이미지 1/2 Nerf N-Strike Firestrike Wire Replacement: 12 단계, 이미지 2/2
    • Use a soldering iron to melt the solder attaching the wires to the circuit board.
    • The positive lead is attached at the middle right of the board, while the negative lead is attached at the bottom right of the board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hayes Kimball
회원 가입일: 04/19/15
742 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G6
3 회원들
안내서 8개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 696
