주요 콘텐츠로 건너뛰기
Nerf N-Strike Maverick Trigger Repair
필요한 것
  1. Nerf N-Strike Maverick Trigger Repair, Nerf N-Strike Maverick Trigger Repair: 1 단계, 이미지 1/1
    • Remove the 10 screws on the outer shell of the Maverick.
    • Make sure to keep all the screws in a cup or container so they don't get lost.
  2. Nerf N-Strike Maverick Trigger Repair: 2 단계, 이미지 1/2 Nerf N-Strike Maverick Trigger Repair: 2 단계, 이미지 2/2
    • After removing all of the screws, slowly lift the gray top left piece.
    • The other side of the top left piece can also be taken off.
  3. Nerf N-Strike Maverick Trigger Repair: 3 단계, 이미지 1/1
    • Remove the top left screw.
  4. Nerf N-Strike Maverick Trigger Repair: 4 단계, 이미지 1/2 Nerf N-Strike Maverick Trigger Repair: 4 단계, 이미지 2/2
    • While holding the Maverick down slowly lift the outer shell.
    • Make sure the orientation of the Maverick matches the picture shown.
  5. Nerf N-Strike Maverick Trigger Repair: 5 단계, 이미지 1/2 Nerf N-Strike Maverick Trigger Repair: 5 단계, 이미지 2/2
    • Remove the screw holding the trigger to the body.
    • When screwing everything back together, remember to re hook the trigger spring.
  6. Nerf N-Strike Maverick Trigger Repair: 6 단계, 이미지 1/3 Nerf N-Strike Maverick Trigger Repair: 6 단계, 이미지 2/3 Nerf N-Strike Maverick Trigger Repair: 6 단계, 이미지 3/3
    • Check the inner chassis around the trigger area. Make sure the springs and parts can move freely.
    • If a part is broken, a replacement will need to be bought or taken from another Maverick.
  7. Nerf N-Strike Maverick Trigger Repair: 7 단계, 이미지 1/2 Nerf N-Strike Maverick Trigger Repair: 7 단계, 이미지 2/2
    • After examining and fixing the chassis, screw the trigger back onto the body.
    • Hook the upper spring to the metal rod.
  8. Nerf N-Strike Maverick Trigger Repair: 8 단계, 이미지 1/3 Nerf N-Strike Maverick Trigger Repair: 8 단계, 이미지 2/3 Nerf N-Strike Maverick Trigger Repair: 8 단계, 이미지 3/3
    • Replace the outer shell of the Maverick and the top left screw.
    • When reattaching the outer shell, make sure to hold the top left piece as shown in the first picture. This ensures that the spring remains connected to the rod.
    • Screw the top left piece back onto the Maverick.
    • Replace the 10 screws on the Maverick.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
David Lim
회원 가입일: 09/27/15
110 평판
안내서 1개 작성함
Cal Poly, Team 10-3, Green Fall 2015 Cal Poly, Team 10-3, Green Fall 2015 회원
CPSU-GREEN-F15S10G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 18
전체 시간: 2,253
