주요 콘텐츠로 건너뛰기
Nerf Recon CS-6 Plunger Replacement
필요한 것
  1. Nerf Recon CS-6 Plunger Replacement, Remove Magazine: 1 단계, 이미지 1개 중 1개
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Nerf Recon CS-6 Plunger Replacement, Remove Visible Screws: 2 단계, 이미지 1개 중 1개
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: 3 단계, 이미지 2개 중 1개 Nerf Recon CS-6 Plunger Replacement, Remove Hidden Screws: 3 단계, 이미지 2개 중 2개
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Nerf Recon CS-6 Plunger Replacement, Remove Plunger Cap: 4 단계, 이미지 1개 중 1개
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 Plunger Replacement, Remove Slide Screws: 5 단계, 이미지 1개 중 1개
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: 6 단계, 이미지 2개 중 1개 Nerf Recon CS-6 Plunger Replacement, Split the Gun in Half: 6 단계, 이미지 2개 중 2개
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
  7. Nerf Recon CS-6 Plunger Replacement, Remove Spring: 7 단계, 이미지 2개 중 1개 Nerf Recon CS-6 Plunger Replacement, Remove Spring: 7 단계, 이미지 2개 중 2개
    • Pull the spring out the back of the gun.
  8. Nerf Recon CS-6 Plunger Replacement, Removing Plunger Guide: 8 단계, 이미지 1개 중 1개
    • Lift the plunger guide straight up out of the gun.
  9. Nerf Recon CS-6 Plunger Replacement, Remove Plunger: 9 단계, 이미지 1개 중 1개
    • Pull the plunger out the back of the gun off of the inner piece.
  10. Nerf Recon CS-6 Plunger Replacement, Remove  Other Half of Plunger: 10 단계, 이미지 1개 중 1개
    • Pull the remaining half of the plunger out the back of the gun.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Asad Qureshi
회원 가입일: 10/22/14
595 평판
안내서 3개를 작성함
Baylor, Team 8-14, Williams Fall 2014 Baylor, Team 8-14, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G14
3 회원들
안내서 6개를 작성함
1가이드 댓글
Do you know anywhere that you can buy a replacement plunger? Thanks
Angela Hirschi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 4,971
