소개
In two steps, this guide will show you how to remove the slide pieces with a screwdriver so that they can be replaced.
필요한 것
Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Ok so the slide is removed now what? It's still stuck
i was thinking the same thing
