주요 콘텐츠로 건너뛰기
Nerf Zombie Strike Crossbow Cocking Mechanism Replacement
필요한 것
  1. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement, Cocking Mechanism: 1 단계, 이미지 1/1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 2 단계, 이미지 1/1
    • The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
  3. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 3 단계, 이미지 1/1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 4 단계, 이미지 1/1
    • Separate each part of the Nerf crossbow.
  5. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 5 단계, 이미지 1/1
    • Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
  6. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 6 단계, 이미지 1/1
    • The cocking device needs to be attached to the plunger in order to function properly.
결론
Benjamin Bucklin
회원 가입일: 10/09/14
61 평판
안내서 3개 작성하였습니다
University of Maine, Team 1-12, Diaz Fall 2014 University of Maine, Team 1-12, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G12
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 3,489
