주요 콘텐츠로 건너뛰기
Nerf Zombie Strike Crossbow Plunger Replacement
필요한 것
  1. Nerf Zombie Strike Crossbow Plunger Replacement, Plunger: 1 단계, 이미지 1/1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Plunger Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  3. Nerf Zombie Strike Crossbow Plunger Replacement: 3 단계, 이미지 1/1
    • Separate each part of the Nerf crossbow.
  4. Nerf Zombie Strike Crossbow Plunger Replacement, Removing the Plunger for Inspection: 4 단계, 이미지 1/1
    • Carefully remove the plunger from the chamber for inspection.
  5. Nerf Zombie Strike Crossbow Plunger Replacement: 5 단계, 이미지 1/1
    • Check to make sure the plunger is intact and has the the rubber stopper at the end of it.
    • Also make sure the spring is intact and is not bent.
    • If the spring is bent you can purchase one similar to it at a local hardware store.
  6. Nerf Zombie Strike Crossbow Plunger Replacement: 6 단계, 이미지 1/1
    • Make sure that plunger is reattached to the cocking mechanism.
  7. Nerf Zombie Strike Crossbow Plunger Replacement: 7 단계, 이미지 1/1
    • Check chamber to make sure that there are no holes or cracks.
    • If there are holes or crakes then the problem will not be able to be resolved since Nerf does not sell these types of parts.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Benjamin Bucklin
회원 가입일: 10/09/14
61 평판
안내서 3개 작성하였습니다
University of Maine, Team 1-12, Diaz Fall 2014 University of Maine, Team 1-12, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G12
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 2,373
