주요 콘텐츠로 건너뛰기
Nerf Zombie Strike Crossbow Trigger Spring Replacement
필요한 것
  1. Nerf Zombie Strike Crossbow Trigger Spring Replacement, Trigger Spring: 1 단계, 이미지 1/1
    • There are 19 1.0 cm screws in total.
  2. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 2 단계, 이미지 1/1
    • Separate each part of the Nerf crossbow.
  3. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 3 단계, 이미지 1/1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 4 단계, 이미지 1/1
    • Take the broken spring off of the trigger.
  5. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 5 단계, 이미지 1/1
    • Replace it with the new spring you bought at your local hardware store.
  6. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 6 단계, 이미지 1/1
    • Now that the spring has been reattached to the trigger repeat step two.
    • Finish by performing steps two and three in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Benjamin Bucklin
회원 가입일: 10/09/14
61 평판
안내서 3개 작성하였습니다
University of Maine, Team 1-12, Diaz Fall 2014 University of Maine, Team 1-12, Diaz Fall 2014 회원
UMAINE-DIAZ-F14S1G12
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 3,617
