주요 콘텐츠로 건너뛰기
Nespresso Pixie Brewing Spout Replacement
필요한 것
  1. Nespresso Pixie Brewing Spout Replacement, Brewing Spout: 1 단계, 이미지 2개 중 1개 Nespresso Pixie Brewing Spout Replacement, Brewing Spout: 1 단계, 이미지 2개 중 2개
    • Before beginning disassembly, make sure there is no fluid left inside the water tank or any capsule in the capsule’s chamber.
    • Unplug the machine from any outlets.
    • Remove the water tank by pressing the top button and pulling outwards.
  2. Nespresso Pixie Brewing Spout Replacement: 2 단계, 이미지 2개 중 1개 Nespresso Pixie Brewing Spout Replacement: 2 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to unscrew both sides of the lever (metal handle) to prevent interference during disassembly.
    • Remove the metal handle by pulling it up.
  3. Nespresso Pixie Brewing Spout Replacement: 3 단계, 이미지 2개 중 1개 Nespresso Pixie Brewing Spout Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the drip tray using your hand.
    • Remove the drip tray grill using your hands.
  4. Nespresso Pixie Brewing Spout Replacement: 4 단계, 이미지 2개 중 1개 Nespresso Pixie Brewing Spout Replacement: 4 단계, 이미지 2개 중 2개
    • Use a a Torx T5 screwdriver to unscrew the screws from each corner of both faceplates.
    • Remove the faceplate using a metal spudger.
    • Start in the corners and carefully separate them.
  5. Nespresso Pixie Brewing Spout Replacement: 5 단계, 이미지 3개 중 1개 Nespresso Pixie Brewing Spout Replacement: 5 단계, 이미지 3개 중 2개 Nespresso Pixie Brewing Spout Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate the two springs in each top right corner and remove them using precision tweezers.
    • Place your hand on the top to prevent the loss of springs and facilitate their retrieval.
    • Use your hand to remove the waterspout.
    • Remove white plastic bits using a screwdriver or metal spudger.
  6. Nespresso Pixie Brewing Spout Replacement: 6 단계, 이미지 3개 중 1개 Nespresso Pixie Brewing Spout Replacement: 6 단계, 이미지 3개 중 2개 Nespresso Pixie Brewing Spout Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the clear plastic bits with a metal spudger.
    • Gently disconnect the power cables from the machine with your hands.
  7. Nespresso Pixie Brewing Spout Replacement: 7 단계, 이미지 2개 중 1개 Nespresso Pixie Brewing Spout Replacement: 7 단계, 이미지 2개 중 2개
    • Use a metal spudger tool and your hands to remove the outer shell.
    • Take your time during this step and initiate the process from the center, where the marker is located.
    • Note these pieces are securely fastened to the machine.
    • Using your hands, gently separate the plastic that is covering the coffee size buttons.
  8. Nespresso Pixie Brewing Spout Replacement: 8 단계, 이미지 3개 중 1개 Nespresso Pixie Brewing Spout Replacement: 8 단계, 이미지 3개 중 2개 Nespresso Pixie Brewing Spout Replacement: 8 단계, 이미지 3개 중 3개
    • Apply steady pressure to both ends of the brewing chamber, pushing it in to extract the lever housing.
    • Remove the lever housing by gripping it with your hands and pulling it out.
    • After separating it, remove the other handle holder using the same method as outlined in the previous step.
  9. Nespresso Pixie Brewing Spout Replacement: 9 단계, 이미지 3개 중 1개 Nespresso Pixie Brewing Spout Replacement: 9 단계, 이미지 3개 중 2개 Nespresso Pixie Brewing Spout Replacement: 9 단계, 이미지 3개 중 3개
    • Pull the brewing chamber cover outwards from the machine, then pull it downwards to detach.
    • Use your hands to pull the brewing mechanism apart from the remaining plastic barrier.
  10. Nespresso Pixie Brewing Spout Replacement: 10 단계, 이미지 3개 중 1개 Nespresso Pixie Brewing Spout Replacement: 10 단계, 이미지 3개 중 2개 Nespresso Pixie Brewing Spout Replacement: 10 단계, 이미지 3개 중 3개
    • Utilize a metal spudger to disengage the clips securing the black case in position.
    • Draw the brewing chamber outward from the machine, and then pull it downward to disconnect the brewing spout chamber.
    • Following the disconnection of the brewing spout chamber, the inner brewing spout will become visible.
  11. Nespresso Pixie Brewing Spout Replacement: 11 단계, 이미지 3개 중 1개 Nespresso Pixie Brewing Spout Replacement: 11 단계, 이미지 3개 중 2개 Nespresso Pixie Brewing Spout Replacement: 11 단계, 이미지 3개 중 3개
    • Utilize a metal spudger to disengage the clips securing the white inner brewing spout in position.
  12. Nespresso Pixie Brewing Spout Replacement: 12 단계, 이미지 2개 중 1개 Nespresso Pixie Brewing Spout Replacement: 12 단계, 이미지 2개 중 2개
    • Examine the coffee spout and the areas through which coffee passes to remove any trapped coffee grounds, scale, or debris, ensuring a clear pathway.
    • Clean the brewing spout thoroughly with a damp cloth, water, and mild soap to remove any remaining debris.
결론
To reassemble your device, please follow these instructions in reverse order.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jose B. Marin
회원 가입일: 11/06/23
442 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G2
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 62
지난 30일: 283
전체 시간: 5,067
