주요 콘텐츠로 건너뛰기
Nespresso Vertuo Next Upper Water Line Replacement
필요한 것
  1. Nespresso Vertuo Next Upper Water Line Replacement, Power Button: 1 단계, 이미지 2개 중 1개 Nespresso Vertuo Next Upper Water Line Replacement, Power Button: 1 단계, 이미지 2개 중 2개
    • Side an opening tool in between where the top cover meets the white head piece and apply force to push the cover off.
    • Remove the cover from the device.
  2. Nespresso Vertuo Next Upper Water Line Replacement: 2 단계, 이미지 2개 중 1개 Nespresso Vertuo Next Upper Water Line Replacement: 2 단계, 이미지 2개 중 2개
    • Use a T19 Torx screwdriver to remove the white top cover of the machine.
    • While pulling away the top cover, ensure that you don't pull out any wires or other parts.
  3. Nespresso Vertuo Next Upper Water Line Replacement: 3 단계, 이미지 2개 중 1개 Nespresso Vertuo Next Upper Water Line Replacement: 3 단계, 이미지 2개 중 2개
    • Pop out the power button by pressing your thumb on the button and pressing down.
  4. Nespresso Vertuo Next Upper Water Line Replacement: 4 단계, 이미지 2개 중 1개 Nespresso Vertuo Next Upper Water Line Replacement: 4 단계, 이미지 2개 중 2개
    • Use tweezers to unplug the wires from the power button.
    • Apply slight force and carefully pull the wire out as to not damage any pins.
  5. Nespresso Vertuo Next Upper Water Line Replacement, Upper Water Line: 5 단계, 이미지 2개 중 1개 Nespresso Vertuo Next Upper Water Line Replacement, Upper Water Line: 5 단계, 이미지 2개 중 2개
    • Use tweezers to remove the clip at the end of the upper water line.
    • Note: You may have to grasp with your other hand and pull the line with your other in order to remove the clip.
  6. Nespresso Vertuo Next Upper Water Line Replacement: 6 단계, 이미지 2개 중 1개 Nespresso Vertuo Next Upper Water Line Replacement: 6 단계, 이미지 2개 중 2개
    • For the second clip on the lower part of the line, repeat the previous step. After the removal of the second clip, the remove the line.
결론
작성자
4다른 기여자 명과 함께
Tyler Nunes
회원 가입일: 03/21/25
85 평판
안내서 1개를 작성함
UMass Dartmouth, Team 6-2, Botvin Spring 2025 UMass Dartmouth, Team 6-2, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S6G2
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 86
전체 시간: 498
