주요 콘텐츠로 건너뛰기
Nest Cam Mic Cable Replacement
필요한 것
  1. Nest Cam Mic Cable Replacement, Mic Cable: 1 단계, 이미지 1/1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Mic Cable Replacement: 2 단계, 이미지 1/3 Nest Cam Mic Cable Replacement: 2 단계, 이미지 2/3 Nest Cam Mic Cable Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Mic Cable Replacement: 3 단계, 이미지 1/1
    • Holding the back panel firmly, use a spudger to pry off the small plastic panel holding the mic cable in place.
    • Use a heat gun to melt the glue keeping the mic cable in place and then remove it.
    • During reassembly this plastic piece may need to be glued back on to ensure the mic cable stays in place on the back panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jade Weiss
회원 가입일: 02/24/16
662 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G1
7 회원들
안내서 10개 작성하였습니다
댓글 3개
Thank you for this look inside the device. In the Nest settings there is a way to turn off the microphone, but anyone with access can turn it back on. I'm going to use this guide to unplug the microphone and permanently (but reversibly) disable it.
Bruce MacDonald - 답글
Yes, by accessing the settings either via the app, or the website. Device options will all you to control the mic recording, or notifications if you just don't want to know when it picks up audio. Each app has its own settings on my devices, I think, but don't quote me on that one.
Be He - 답글
Good job.
Do you have any idea if the cam doesn't restart?
Thanks.
Summer
summer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 25
전체 시간: 3,701
