주요 콘텐츠로 건너뛰기
Nest Cam Motherboard Replacement
필요한 것
  1. Nest Cam Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Motherboard Replacement: 2 단계, 이미지 1/3 Nest Cam Motherboard Replacement: 2 단계, 이미지 2/3 Nest Cam Motherboard Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Motherboard Replacement: 3 단계, 이미지 1/2 Nest Cam Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
  4. Nest Cam Motherboard Replacement: 4 단계, 이미지 1/3 Nest Cam Motherboard Replacement: 4 단계, 이미지 2/3 Nest Cam Motherboard Replacement: 4 단계, 이미지 3/3
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Khiry Jones
회원 가입일: 02/29/16
156 평판
안내서 1개 작성함
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G1
7 회원들
안내서 10개 작성하였습니다
댓글 4개
where can I get a MoBo for my drop cam?
mikelebp1 - 답글
where can i find a motherboard replacement?
Steve - 답글
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - 답글
same here, no where to be found online
chantalder - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 48
전체 시간: 24,330
