주요 콘텐츠로 건너뛰기
Nest Cam Outdoor S Battery Replacement
필요한 것
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: 1 단계, 이미지 1/2 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: 1 단계, 이미지 2/2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: 2 단계, 이미지 1/1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: 3 단계, 이미지 1/1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: 4 단계, 이미지 1/2 Nest Cam Outdoor S Battery Replacement: 4 단계, 이미지 2/2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: 5 단계, 이미지 1/2 Nest Cam Outdoor S Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Phelix Gaudette
회원 가입일: 10/28/21
275 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G6
2 회원들
안내서 4개 작성하였습니다
댓글 2개
Do you have the P/N of the battery??
Richard K Yabuki - 답글
Where to buy a replacement battery?
Ted McKenna - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 54
30일 전: 239
전체 시간: 6,449
